- 20 Oct 2002
- Derby
Anyone know if you can get one of these on thier own for a little bit of cash? i upgraded my original one and have now put it all in the Lian Li chassis but i have just managed to resurect another one and although i have a 256mb card it would be nice to use the 20gb even if i have to mount inside.
The bit i need is the bit that actually plugs into the hdd then into the socket on the console...
Did see a guide somewhere that you could fit it internally by splicing into the wires and fitting a normal s-ata plug and s-ata power but cant find it..
