xbox 360 hardware snags.
18 Oct 2002
"Sunny" Plymouth
Used the xbox a few days ago, everything was fine, turn it on today and it won't connect to the controllers, or output a video signal (tv will only switch to hdmi input if there is a signal to use)
It does turn on if you turn on one of the controllers, but it won't connect (none of the segments light up)
If you push the sync buttons on the xbox and controller the segments spin round a few times, then all flash, but it still won't see the controller.
No green lights, no red lights.
Any ideas?
Ahhh, googling "no ring of light" led me to a loose video connection.
Unplug hdmi lead, plug in hdmi lead, works again.
Job jobbed :)
