i dont have this yet but can i use this as a boot drive on PC, so i can install windows?
Yes you can, I used it to install windows on an asus eee![]()
A workmate spent a fair amount of time trying to track one down. Ended up resorting to that online auction place and got one for about 20 quid, used.Had no luck finding stock, seems most places have now shifted what they had.
I grabbed one off there last night, a seller on there is selling a load of new ones, picked it up for £20 inc p&p.A workmate spent a fair amount of time trying to track one down. Ended up resorting to that online auction place and got one for about 20 quid, used.
Probably the same seller I got mine from (their are selling loads of them), turned up within 48hours delivered by DHL, was impressed.I bought one off the aution site last night, I ended up paying £18.02 + £4 postage.
Does that popular 2nd hand games shop have much stock? For £10-£20 it'll make a handy external drive. Can you still get Hd-dvds pretty cheap?
Yep, came with the remote and a euro plug, but that's not fixed connected to the PSU so you can just replace it with any 2 pin power cable (or cut replace the plug).It sure sounds like the same seller, was it new as described and did it come with the remote? In the description it says that it may come with a european plug, did yours?
Thanks
Deleted member 2277
