XBOX 360 HDMI + OPTICAL
Is the problem currently that you can't fit both connectors in at the same time? Or am I thinking of a different problem ? :p
If it is the problem, you can just remove part of the casing on your non HDMI connection thing and then they both fit. I think.
Did Microsoft change the design on the non-hdmi adapter because I use that for the optical and a standard HDMI lead on my elite and did n't have to cut anything. It all just fits.
