- 28 Sep 2004
- westmidlands
Hi guys and gals...i have a quick question about using a hdmi cable with a xbox 360, i'm using the official vga cable at the moment to connect up to my monitor, and while it's a very good picture..the colours aren't as vibrant as when using a component cable connected to the tv in the lounge...would purchasing a hdmi cable and dvi convertor adapter fix this ?
Thanks in advance
Thanks in advance
the reference level is set to intermediate..which is the second one, i shall try expanded see if that helps.
