XBOX 360 Headsets
18 Oct 2002
Staffs Moorlands
What headset would you recommend, at the most £50? We've been using the standard ones up until now but fancy something a bit better.
Don't stretch for the PX21, you can buy a Turtle Beach Foxtrot which is a COD MW3 branded PX21 that can be had for under budget easily :)
Thanks for the suggestions.
Just had a look around and the px21 seems to have had some issues with poor wiring quality, well looking at some reviews. So may get the X12 unless someone knows otherwise or that they have improved them?
squeeze a lil more out for some Tritton Black Ops Spec Editions AX720 - they are available for around £60-£65 online and the bonus for me is that you can use them on PS3, 360 and PC so no need to mess about with separate headsets for each. I got a pair and like them a lot.
