- 15 Jun 2006
- Amsterdam
PCPerspective has posted a review of the Xbox 360 HD-DVD accessory today for your viewing pleasure. Here's a taster:
Now for the fun part, and the part that I wasn't expecting when I went out to buy this drive. It turns out, thanks to the standard USB connection that the Xbox 360 uses, you can use the external HD-DVD drive on your PC; and it's easier than you might think. Simply plugging in the USB cable to the HTPC system will present you with the standard "New Hardware Found" wizard. Clicking next through the process will not find any drivers and you'll be left with the above results in the device manager on your system. What is important to note though is that even though the Xbox 360 HD DVD Memory Unit devices do not have drivers, the Toshiba DVD/HD X807616 USB Device is showing up as a working device in the DVD/CDROM drives section.
Looking at the drivers in more detail, you can see that the device that DOES have drivers and installs correctly on Windows XP shows settings like DVD Regions that indicates some functionality. It turns out, that even without a driver for the external device, the ability to read the data on the discs is native to Windows XP. Now, that being said, you WOULD need a driver to read the data structure of HD-DVDs, if you wanted to look at the data on the disc in Windows Explorer for instance. But to just play the HD-DVD movies, all the software required is built into Windows and the HD-DVD playback software.
Speaking of that software, here I was able to get my hands on a copy of CyberLink's PowerDVD HD-DVD Edition to give this test a shot. Actually, the HTPC system that I have the Xbox 360 HD-DVD drive connected to also has a standard HD-DVD drive in it that I am using for some other testing, to be published later. This software was included on it and worked perfectly with the Xbox 360 HD-DVD drive.
It looks like the 360 HD-DVD is completely compatible with your Windows PC. You do have to have a HTPC compatible video card to watch movies but it's good news none the less.Looking at the drivers in more detail, you can see that the device that DOES have drivers and installs correctly on Windows XP shows settings like DVD Regions that indicates some functionality. It turns out, that even without a driver for the external device, the ability to read the data on the discs is native to Windows XP. Now, that being said, you WOULD need a driver to read the data structure of HD-DVDs, if you wanted to look at the data on the disc in Windows Explorer for instance. But to just play the HD-DVD movies, all the software required is built into Windows and the HD-DVD playback software.
and it does come with king kong.
