Xbox 360 ICS problem
21 Oct 2002
30 miles north of London
HELP !
I'm trying to connect a Xbox360 to the internet using ICS with a XP box + wireless card and it falls over at the checking DNS stage
1. The xbox connects fine direct by cable through my router (Dlink 655)
2. It works fine wireless using a genuine Xbox adaptor (can't use it, long story :))
3. my existing network uses IP adressess 193.168.11.xx
4. Firewalls are all turned off
5. I get the same results with the Xbox set to auto as manual
It checks the network, gets an IP then goes FAIL for DNS.
PC is 100% stable with up to date drivers and still has full connection to the Internet / LAN
any pointers / info however patronising will be gratefully recieved :)
Thanks
Ps. I've googled & used search the forum :D
I've got it working through my Vista laptop:D , still won't work through my spare XP box though :(
Still should keep me going until christmas :cool:
