XBox 360 Minecraft - Single strike removes blocks/items
15 Nov 2003
Marlow
In lots of videos I watch, it takes repeated blows to remove (mine) a block or item. But on the XBox 360 game in construction mode, a single hit removes anything.
Is this simply to do with "construction mode"? Or a 'feature' of the 360 version?
Reason I ask is, a single wrong key means you've chopped away something. Ideally I'd like it to take a couple of chops...?
You're essentially i ngamemode 1, a single chop will remove blocks, but you can spawn new blocks in etc;
It's also in the PC version. If you break the block, you don't get it either.
