Xbox 360 on a LCD
5 Jun 2005
Southampton
my VGA cable should come tomorrow and i intend on using the xbox 360 on my samsung TFT, it has a 1600 by 1050 res (i think :) ) do i need to make any changes before setting it up? as it have been used on a bulk standard tv prior to this
Doesnt have the option of 1650x1080 till the update is implimented... :( I just found out that the max res that my 46" TV will accept via vga... :(
ok my samsung default is 1680 x 1050, so what is my best option (i don't have the xbox or cable yet)
my samsung is the same res afaik (i cant check right now im offshore) but i think i have mine set to 1280x1024....i think
however the next update for the xbox360 will include 16:10 support so you will soon be able to have the res at 1680x1050. When you connect the xbox over vga just have a look at the resolutions and decide which one you think is best :)
thanks mate, i don't have wireles in this xbox, wonder if they have a newtwork cable :) (xbox noob here) he he
heh :) no worries mate, if you want wireless you can buy a wireless adaptor but its around £50. But they do come with a network cable to plug into your router for net access its all very simple
