Xbox 360 on monitor
Yes, it is, but use the search dude, its been covered plenty of times.
To do it, you need to buy a component cable, which goes from the XBox to VGA. Most high street game retailers have them.
Cheers,
Matt.
If you are using a monitor it will let you choose a resolution rather than 720p etc.
[EDIT] And if I recall correctly only the 24" dells have the 1920x1080 resolution option[/EDIT]
Yes dude, Also get the Offical MS one as all others are pants and you'll have problems. Unless you pay like £60+ for the Monster one.
I mad the mistake of getting a Madkatz one and it was rubbish and I wasn't god know how much petrol driving around trying to find one.
Stick to big high street music stores and you can't go wrong, Also the MS one come with a Phono to 3.5mm jack whch is good as i plug it into my pc sound card and then run it though the PC speakers.
A[L]C;10678834 said:
Hi all,
Is it possible to connect an xbox 360 to my dell 22" monitor?
ta
