Xbox 360 or Helicopter?
  • Thread starter Thread starter Sam
  • Start date Start date
Sam
Sam
12 Jan 2003
Surrey
Hi Chaps
I have had a new style 250GB xbox 360 for under a year and just recently it has become incredibly noisy. I purchased this to replace an old style and one of the reasons i decided to replace was because the new style is allot quieter.
Is this a common issue with these units, mine sounds like its about to take off and can be quite distracting. Can i get this replaced by Microsoft?. Any Advice of guidance would be appreciated.
Thanks
Sam
Good plan ill give that a whirl tonight
Also it is laying on its side and always has been :)
I believe its the fan however whilst having a bash on fifa later ill have a proper listen and report back. Its defiantly not normal i know that much
Sam
Have you installed the games you're playing. It might be the disc tray making the sound. If you install the games it makes it a lot quieter.
Another to add to the "to do list"
I will report back this eve :D
