Xbox 360 Problems (Network, Not ring of death)
29 Oct 2002
Land Of Pork Pies!
Hi All,
Just a bit of help required here as it is sending me mental. I have a Linksys 54G router which is absolutely sound! I have a network cable leading from the office into a wall plate through the house coming out of the wall.
Now when I dont connect the cable to the hub and run a test on the cable with my lan tester, it confirms that it is a straight through cable. So I plug the cable into the Linksys router and then the other end into a GigaX1005 hub, I only have one device connected to the GigaX(along with the cable to the hub) and this is my Xbox 360. This is connected by a straight though hard wired connection to the xbox.
When I run the Test Xbox Live Connection it confirms it is a wired connection and it collects an IP address, then a DNS, then it randomly fails on MTU & ICMP. It is sending me whappy, is there anyone that can help?
Is my cabling correct, I presume so otherwise I suspect I wouldnt even get a IP address.
Any help would be much appreciated
