2 Nov 2009 at 11:18 #1 Puppetmaster Puppetmaster Soldato Joined 17 Jun 2005 Posts 6,515 Location Near Brighton Anyway i can tell from the console, which psu i need to get for it. Need a replacement Thanks
2 Nov 2009 at 12:09 #2 sven256 sven256 Soldato Joined 18 Oct 2002 Posts 3,074 Location manchester If you get a 203 watt one, it will run on any xbox360.
2 Nov 2009 at 12:11 #3 Puppetmaster Puppetmaster Soldato OP Joined 17 Jun 2005 Posts 6,515 Location Near Brighton really? i thought the connectors were physically different?
2 Nov 2009 at 12:13 #4 Memphis Memphis Soldato Joined 13 Jan 2004 Posts 12,197 Location Inverness They are on the lower power PSUs, however the 203W unit will work on every machine after. EDIT - As for determining exactly what PSU you should have, you need to look at the current rail on the back of the console itself: 16,5A = Zephyr = 203W 14,2A = Falcon = 175W 12,1A = Jasper = 150W Last edited: 2 Nov 2009
2 Nov 2009 at 12:24 #5 Margaret Margaret Permabanned Joined 15 Nov 2006 Posts 16,474 I have an un-used Falcon power supply for sale, if you need one then email me via trust.
