XBOX 360 rattling Noise Inside
24 Mar 2005
KENT
Guys
Just got my New Xbox 360 it's making a rattling noise whilst I was unpacking it.
Any idea what the rattling noise inside the 360 is?
thanks
What sort of rattle?
The switch type thing that detects whether the console is vertical or horizontal (so it can display the ring of light properly) makes a small noise when you move it.
Ive got a feeling its something to do with the moving parts on the laser/cd tray mine does it too noticed it more on this last one than the first 2. Never rattles when running just when unpacking it etc.
thanks mate thats what it is
many thanks
