Xbox 360 reference and color space settings - Help
1 Dec 2006
Amsterdam, NL
Right, last night I was playing around with the settings on my 360 and have found the best settings to be Expanded in reference and RGB in color spacing. Is this correct with my following setup? I am using a samsung series 6 37" and the xbox is connected via HDMI (it says HDMI+A what ever that means).
Is there any way I can get a picture up with those bars to adjust the TV settings to and 360? As all I am doing it judging by eye.
Thanks, ags.
i'm using the same setup (set mine as Source not RGB but same thing really) after trying all the modes it looks right to me on my pc lcd screen.
I use normal, I tried using expanded but then I discovered I was losing some detail in the darkest regions which i didnt like.
Not obvious on some stuff, but as I could on some games, I prefered the increased details. Could be down to my amps inability to pass the full RGB range though.
Get the picture and stick it on a USB pendrive.
Any suggestion on what picture I should use?
The details on all this are very vague on the internet. I guess without a picture showing me what should be right, I have no idea what is best.
ags
