Xbox 360 steeing wheel and forza3
1 May 2003
Blackpool Lancs
Having just bought the console and played forza a couple of questions..
Does forza 3 support clutch usage?
also is there a 3 pedal setup for the 360?
And if not whats the best 2 pedal job for the 360 atm..
the MS one?
Thanks
forza 3 does have a manual with clutch option, but i dunno what wheel/pedal setup the forza 3 supports.
There are only really 2 wheel options for the Xbox360:
MS Wireless Wheel
It's ok, pedals are (imo) the biggest weakpoint, but then that's coming from the G25 pedals which are massively better (I believe there's a mod to use the G25 pedals on the xbox wheel, gonna be trying that shortly)
Fanatec Turbo S
Very expensive, not tried the wheel but pedal options include the fanatec pedals (can't be worse than the MS ones), G25 pedals which are good, and the clubsport pedals which are apparantly even better again, so I can imagine it being a vast improvement over the MS wheel, but at >3x the price I'd expect that :p
Microsoft racing wheel looks like something you would see in the early learning centre, such a shame they dont support logitechs wheels :/
the wheel is actually nice to use, but as mentioned above, the pedals let it down, they are spring loaded as opposed to gas like the G25 / G27.
I'm not sure about the G27 supporting the Xbox, i know the 25 doesn't but i thought the G27 might have being quite a large market.
Thanks i just wanted to know if the xbox detected it in any way, that could make it work but i guess not becasue it would be great if it did work with teh xbox :(
could you use g25 pedals with the microsoft wheel?
Apparantly if you get a DB9 socket and wire that on one end of the RJ11 cable you get with the ms pedals then you can use the throttle/brake pedals fine, which I intend to do,
Broke my wrist a week ago on saturday so not been back to work yet but there should be a DB9 socket waiting for me there, then just some soldering and hopefully I'll be using decent pedals on the 360 :)
