XBOX 360 Upgrade Advice
Caporegime
18 Oct 2002
Lake District
I want to get 120gb hard drive for the 360 but I'm not sure how to go about it, I have 2 options really.
Buy a 120gb hard drive for £90
Or, Trade in both my Premium and Arcade consoles for £60/£80 respectively and then pay the difference (£110) to get an Elite with Fallout 3.
But then of course if the Elite breaks I won't have a backup, so what should I do :confused:
Look around for a 2nd hand 120Gb HDD for about £50. You save £60 and you get to keep an extra console.
Surly this is a really simple question!
HDD for the win! otherwise your paying £20 and a console for fallout 3!
Phone up xbox support, tell them your hard drive has gone, but your mates one works in the machine. They send you new one. Fingers xd its a 60gb or higher
Worked for me (my hard drive had gone tho, free upgrade and fixed xbox :))
Just to note only one of the two consoles are in use, the other one is unused in a box.
