NokkonWud said:![]()
Sorry, it was 3.5mm, not 2.5mm.
WHAT!!! said:sorry if i have not made my self clear![]()
NokkonWud said:I'll take it that the rolleyes wasn't meant as an insult, for which it appears. Get one of those and a female-to-female adaptor.
WHAT!!! said:nope was'nt intended as insult just i was'nt sure if i explained what i was after proplery hehehe
The offical xbox 360 VGA cable comes with one so im told, i ordered one from a absoulte joke of a company which was almost 1 month ago now and they have now sent me a joytech vga which does'nt have the connection adapter.
NokkonWud said:Yes, the adapter you get with the Official is the one I posted, you need one of those and a female-female if your speakers are male. Though, these are no replacement for Optical, if you can hook up optical through 5.1 in any way it's really worth it, even at the expense.
DaveyD said:You want a "3.5mm coupler". Easy.
On a note about the Black/Yellow/Green connector, I'm not sure. How old are the speakers, what brand? Are they connected to an amplifier or are they 5.1 speakers?
DaveyD said:Those connections are for Front Left/Right, Rear Left/Right and Sub/Centre.
You could get 2 channel sound out of the 360 using a coupler on there, but you would not be able to get 5.1 sound from the cable without using the optical connection and some sort of dolby digital amplifier/reciever to convert to analogue 5.1 channels for those speakers.
WHAT!!! said:what sort of couplers would i need to do this please (is there a name or term for them), as im quite happy to have just 2 speakers with sound and as this speakers are on my desk it would be brillanty to use things instead of dragging the other ones from other PC and having even less desk space
WHAT!!! said:just found this
A 3.5mm stereo plug to two phono sockets (one carries the left channel and the other carries the right). Allows twin phono plugs to be connected to a 3.5mm stereo socket.
would i be right in thinking this is what im looking for to get say either my 2 front or 2 rear speakers to work ?
