Xbox 360 VGA cable
21 Dec 2004
London
Hey guys. I've hooked the cable to my monitor, but the monitor has only got one VGA port, meaning i've gotta keep swtiching VGA cables whenever I want to use the PC / Xbox.
The monitor is a dell ultrasharp 1901FP HAS. Is there any thing I can buy (some kind of splitter?) that will allow me to hook up both VGA cables to the back of my monitor at the same time?
Any help would be great. Cheers
The converter comes with the official VGA cable and none of the other VGA cables are worth thinking about buying, their quality is apalling in comparison.
I've got the Joytech one, and it seems fine to me.
So do I need to buy a convertor as WolfR1der said, or can I just buy the KVM switch? I'm confused :confused:
The monitor cable goes into the switch.
The Xbox cable goes into the switch.
I think you just need a KVM VGA lead to go from your graphics card to the switch.
You can get a DVI-VGA cable for about a tenner which would be inherently cheaper.
Belkin Pro Series Digital Video Interface Cable (DVI-IM/DB15M;ANA/VGA)-10’
Ok brilliant. I'll do that then.
Regarding male and female types, I'm useless. Don't I need the DVI out to to be male, and the VGA out to be female?
One last thing guys. I've been look at DVI pin layouts, and found this:
http://www.cable4pc.com/jpg/all.jpg
Now the DVI port on my monitor is the DVI-D (DVI Digital) Dual Link. But most of the DVI adaptors come in DVI-I form. Is this still compatible? Could someone please inform me on which adaptor I should get, because I'm seriously baffeled at the moment!
Thanks.
Check your equipment is the best idea. From memory, all graphics cards are female and your monitor's connectors will be female, too. So the Belkin cable which is male at both ends should suffice.
