Howdy.
Out of all the millions of HDTV's in the world, I happen to have one that doesn't have component input, which is like the standard HD input for earlier xbox's I believe...well that's what mine came with anyway.
So anyway, will microsofts VGA cable give me a good HD picture on my TV? It has a VGA input for a PC.
Has anybody/does anybody use this? In most reviews I've read practically all people seem to be using it to connect their xbox 360 to a computer monitor, whereas I want to connect to a HDTV, so was just wondering if there would maybe be any problems since monitors are good friends with VGA input as standard. (for lack of better phrasing..)
Logic simply tells me that it should be fine of course, but just wondered if anyone uses VGA from xbox to HDTV.
Cheers.
Cheers.
