Thinking about gettting a xbox 360 in the next next week or so (shh dont tell the girlfriend
) i am planning on hooking it up most of the time to my tft which i will share with my pc.
Is there any way to plug my pc and the xbox 360 into the same monitor at the same time? i dont have to keep swapping cables around if i can help it. my tft only has vga input so cannot plug one into dvi and vga
can any one help
) i am planning on hooking it up most of the time to my tft which i will share with my pc. Is there any way to plug my pc and the xbox 360 into the same monitor at the same time? i dont have to keep swapping cables around if i can help it. my tft only has vga input so cannot plug one into dvi and vga
can any one help
