xbox 360 wire
16 Mar 2007
hi,
i need a wire so that i can use my xbox on my pc monitor through vga, but also be able to plug in headfones to get sound. is there any way?
thanks
One of these should do for audio:
You plug the red and white audio cables in and plug it in to an audio source. Only cost a few quid.
get the official microsoft vga cable. you get the above connector with it also
but as has been said, if you plug your earphones directly into that, the output volume will be pretty low and you'll need some form of audio amplifier to amplify the sound for your earphones
