Xbox 360 wireless adapter connection interrupted
16 Nov 2011
Nottingham
Thought I'd post this here as it isn't really anything to do with Xbox itself, just the connection to it.
I've gotten a new monitor on my desk, thus I can't connect to Xbox Live anymore via a wired connection.
So I have the G wireless adapter and everything was good until I went into a game on CoD. About half way through the game I disconnected from the game after getting a connection interrupted error, I was then disconnected from the party I was in, but not from Xbox Live. I was then taken out of the game and reconnected to the party.
I know this is something to do with the wireless adapter as this never happened before when I was on a wired connection.
My NAT type is Open...
Thanks, (and Merry Christmas).
Sounds normal. WiFi will never be as stable as a hard wire, I've experienced rare signal drop-outs even within 3 feet of my router.
You can try moving your router and adapter closer. Or you can do some sort of WiFi site survey to see if you're getting interference from other access points, and then set a manual channel number accordingly.
