Hi, i'm trying to set up my brothers xbox up to use his PC's wireless connection so he can get on to LIVE etc but it's not working. When I bridge the LAN and wireless it disconnects the wireless. After a while it will reconnect but it won't let me on the net.
The bridge is reporting an invalid IP address but even when I enter this manually it won't work. It's set up to use DHCP anyway.
Anyone got any ideas for this?
Also when using a VGA connection to his monitor (22" Digimate) it's looks washed out and rubbish. Should I be using the DVI connection instead?
Thanks.
Thanks.
