XBox 360 Wireless controller for PC
27 Nov 2008
Hi Guys,
I'm thinking of getting this wireless receiver so I can play my PC games through an XBox wireless controller.
I have been looking around the net and there was some mixed reviews, just wonderin if you have found any issues?
Please give me your views :)
Never had any problems meself. Worked very well. Even used the wireless headset through it for Skype for a little while.
If the games your are going to use it with are under the Games for Windows brand then the controller should work without any problems. If your trying to use it on older titles, or non-Games for Windows ones, then you may need to use 3rd party software to get all the controls set as you require them.
Cheers, I was wondering about any supporting 3rd party software. Thanks a lot lads, it looks like am about to order one then and getting playing on the pro evo!
Mine has been perfect, finally used it after spending 4 months trying to sell it :p
Might get a 360 wireless headset now to use with that and the 360 :)
I did have some issues with a logitech mouse, I couldn't get both working at the same time, and I'm not the only one..
When it does work, it's great, and seems very reliable/quick responding
