Xbox 360 X clamp kit
3 Jul 2007
Rochdale/whitworth
Hi guys i have a 360 with the RROD and its an year over its warrnty so im going to try the x clamp fix and i was wonding where to get it and which is the best?
my xclamp fix worked for 5 months until it suffered some sort of hardware error.
It's as though some software inside has been corrupted :(
yeh i have been looking on there but there are different ones
I've seen kits include either metal spring washers or crushable nylon. Three friends and I have used the metal washer kits with varying success. We all applied high quality PC thermal paste and I lapped both heatsinks.
One machine lasted just over a month, one 6 months, another almost a year. Last I checked, mine's still working and produces significantly less noise than ever.
i did this to my console, had metal spring washers. xbox lasted another month while i completed arkham ayslum and then packed up again. its a short term fix if anything
As above, results are mixed. I have done hundreds (using all-metal washers) and about 10% come back fairly quickly. A lot of them are still going strong a year later though, so for the amount of time and effort it takes you have nothing to lose by giving it a go :)
cool
Phone m$, tell them your 360 has lasted 4 and half years.
Im sure they would fix it out of shock! :D
OT
Done a few myself, as said some go for another year, some few weeks!
I did this with a couple of screwdrivers and some pliers :D
I didn't have the RROD but had it apart anyway to change my drive laser so decided to replace the thermal paste whilst it was open, been much better since actually!
