silversurfer said:You can buy a special vga cable for the 360 to use on the monitor, it doesnt involve the pc at all
WotDa said:Best £20 I spent. Also has digital audio (optical) aswell.
So, my 19" monitor isn't the same size as the 28" TV, so what? The quality difference is amazing.
Hamoodii said:What do you mean quality, like would it be better than my standard TV quality?
____ ___
|Xbox| ----- |VGA| (Monitor)
| ____
|___ |Audio| (Amp/Sub/Whatever)
Chadd said:Does the VGA lead have a optical out port for sound like the component cable does?
It's on the plug that goes into the 360.
WotDa said:VGA cable has a VGA plug, and the red and white audio leads.
It comes with a red/white ---> 3.5mm Jack to plug into your amp/sub/whatever or you can use it without the jack.
Not sure if that answered your question or not. So I'll do a doodle
Code:____ ___ |Xbox| ----- |VGA| (Monitor) ----- | ---- | ____ |___ |Audio| (Amp/Sub/Whatever) -----
Well, you get the idea, I hope.![]()
