- 9 Apr 2007
I have a couple of questions about the 360...
I've had the premium since launch and I haven't been playing it much lately. I usually turn it on about once a week or two. The problem is that every time I turn on one of my controllers the 4 lights blink on it for a second, then it just stops and does nothing. It won't recognize the 360 even though they have been working and have been synced up for ages. If I plugin my play and charge cable then disconnect the cable, it works fine for that day. I try it the next week though and it doesn't work again...
Is this because I haven't been using it much or is there something wrong? I know it's not that much of a common problem but I was hoping some people here might be able to help.
The second question is about the HDMI cable that comes with the Elite. Is it possible to buy the separate optical adaptor that comes with the Xbox 360 Elite? My 360 is really loud and I've heard the Falcon is a lot quieter, I also don't think my launch 360 is going to last that long and if I got a Falcon I would want to use HDMI and 5.1 (my received needs an optical connection).
I know there is a trick with shortening down one of the component cables so that you can fit the optical cable and the HDMI cable in at the same time but I'd rather just buy one of those cables to keep it tidy. I can't see them on any auction sites, so I was wondering if anyone has seen them being sold separately?
Thanks in advance
Thanks in advance
