Xbox arcade
18 Oct 2002
ok so my xbox is the cheap one. arcade i think they are called.
im wanting to get a new tv to get the best out of it but im not sure whether i need to bother with a full hd set or not. i have no other hd devices, but is it still worth going for the 1080p sets?
Current consensus appears to be that 1080p is not really necessary until you get over about 42" screen size or you sit very close to your TV.
If you're not watching Blu-Ray films as well you'll probably be fine with a 720p TV.
I got a 1080i screen (Toshiba 42WLT66) a while back, would've gone for a 1080p had they been a bit cheaper back then. More than happy with the i though, you'll only notice a difference (imo) when watching blurays.
Does your xbox360 have an HDMI port? I know some of the older cheaper versions didn't have one
Get the 1080p screen, you TV will no doubt last a lot longer than any console you use with it.
No doubt the next playstation and xbox will run games at 1080p as a minimum.
