Charge kit does not work on PC you need this or see if you can buy the wireless USB receiver on its own but not sure they make it anymore as a standalone only woth the wireless 360 controller as well.What the hell am I doing wrong? I'm using the play and charge kit connected to the PC and windows is detecting it but its not allowing me to select it as an input for dirt3
Any ideas?
Just seems a bit stupid because the play and charge kit works fine on the Xbox so it does carry data, just clearly not understood by windows. Even though when I plug it in, it knows exactly what device it is :S
