Xbox headphones
16 Jul 2004
Home
So I'm looking for an over-ear headset for three uses:
Connect to TV (Bluetooth)
Xbox series X (primary use)
occasionally with windows pc.
I like the turtle beach stealth 600 gen 2, but that doesn't tick the Bluetooth TV box and I'm.v confused about connecting to pc too.
If I got generic bluetooth ones, I assume that I can just get sound from Xbox through TV Bluetooth to the headset, but that may be too much delay?
Does anyone have a suggestion? I feel like something is going to have to give in my impossible pursuit!!
Expensive but think the Audeze Maxwells should do this, I had the previous version the Penrose X and pretty sure I used them on all three, struggling to remeber bluetooth to TV but they have bluetooth. I think if I went for one headset it would be these, sound on planar are amazing as well
Ohh thanks!! Just checked the price - I probably should have mentioned I want the world for less.than £100. Hahah. I think it's impossible.
I really like the Official Microsoft Headset, seems to tick all of your boxes.
Can even connect it via Bluetooth and to your Xbox at the same time. I'd assume you have bluetooth on your PC so you can connect it to that via BT.
I think Kyle009 has the winner if you want this under £100. My suggestion would have been the Steelseries Arctis 9X, there's also a new Nova range but I'm not as familiar with those.
Cheers all.
I wondered about the TB stealth 700 gen 2. Mid price and rated better than the official Xbox (albeit twice the price)
Take alook at the razor kaira pro wireless they work fine on everything and don’t break the bank to buy .
All the best
I’ve the Penrose X which are suberb, but things can get a bit warm as these cover your ears.
I also use the 1more triple driver earbuds, the mic also works for online chat/gaming and the sound quality is right up there. These are currently £70 on Amazon, you could spend a little more and get quad driver versions for even better sound. I’d highly recommend the 1more’s been using them for years and these are a superb value.
Although it would be amazing if the AirPods Pro’s worked with Xbox as these are my personal fave headphones.
I got the arctics in BF sale the other week. They really are as good as everyone on here says. Best ones I’ve had for sound quality however my only gripe being I find it a bit fiddly to mute the mic. Yeah it’s only one button but it’s not easy and when not muted the mic, even when pushed all the way in, seems to pick up some sort of weird noises which you can hear in the cans. Hard to explain and I’m doing a bad job of it but awesome in game, not so much out of it.
