- 20 Dec 2007
- Nottingham
I've been toying with the idea of getting a Mini ITX system for a couple of weeks now, as i no longer use my pc for anything offer than internet usage and watching movies.
So the plan is to get a zotac 9300 MB, 2x2GB Ram, Blu ray reader and an E5200.
But wasn't sure on which case and psu to go with. Been looking for a while, i do quite like the SG05, but came across an xbox that had a similar system in it. And fancied doing that instead, or at least giving it a go anyway
So after searching i found a faulty xbox for £6.50 + P&P, now awaiting delivery.
Now my problem is fitting everything in, so i'm going to order the MB first so that i can measure up around it. May have to go for a 2.5" HDD, and a slimline Drive, in which case it'll be a DVD drive to save cost for now. My main concern though is fitting a psu in there with everything else and the heat that generates. I think i can fit a shuttle psu in there, but even those are pretty large in conparison to everything else.
Would a picoPSU-120 12V DC-DC ATX PSU with a 110 Watt adaptor be adequate to power this, i've check on one of them power calculators, and it gave around 140W, but i read these can be as much as 100% out?
