I have ordered an 360 and xbox live I currently have a pc with a wireless router.
to connect the 360 to the wireless router and play xbox live do I have to buy any wireless adaptor for the xbox?
Nope. You could connect it via cat5 to the router.
If you want to connect wirelessly then you have to use a wireless adapter or bridge. Microsofts one works nicely, looks good and is a favoured option amongst a lot of us. It is around £60 but as little as £45 online.
Not with a decent spi firewall it doesn't. I've posted on other forums and you need to open a rule for udp 88 as a rule 3074 TCP/UDP gets picked up through uPNP, though.
