XBOX Live Gold
27 Jul 2006
Huddersfield
Where is the cheapest (UK) place to get this curently, i originaly got it on the original Forza for the XBOX and then traded the game in.
Anyone know if this can be still done or somewhere with a decent price.
Thanks
zero
(appologies if this is against forum post ruleS)
Dont go for the cheap ones, they are created used Key-Gen's. Mine was suspended as a genuine customer tried to create an account from a shop bought code and couldn't as it had already been used.
No fault of my own and I got a full refund, but meant I had to start a new Live! account.
:eek: didn't know that! I brought a £28.99 off eBay, hope it was a genuine code :confused:
Going a bit OT but why did you have to create a new Live account? does that mean you lost your ranking etc?
Thats a bit unlucky, I payed £12 for a supposedly 12+1 month code in august 07. It then got activated in november 07... And now runs out in November 08. Thats 15 months for £12. Bargain :D.
theres isnt any other way that he can get hold of so many codes
unless he is genuine and doesnt want to pay for any postage, so just gets rid of the card after he has emailed the code to you
theres only one way to find out eitherway :p
As long as you have the physical card infront of you with the number that you can use as evidence then you will be find. The seller I bought mine from wasn't prepared to do this so the Xbox Live team were not prepared to do anything other than suspend my account, which is fair enough really.
Wasn't my fault at all but the account remains suspended. Yes, I had to start again but luckily I only had a few halo and PGR4 saves under that profile and i'm not fussed about gamerpoints (I have a social life :p).
Thanks
zero
Cheapest place to get online play you ask? Try PSN ;P
