Xbox Live Trial Code?
31 May 2005
Alfreton,Derbyshire
Does anyone have one? Or is there somewhere I could get a free trial from? Just got a second hand Xbox and want to have a look at whats on offer.
Thanks
I think you'll get xbox gold free for the first month any ways! give it a try, i've done it a couple of times on my bro's xbox :)
EDIT:
You can get three free Xbox live months one at a time if you want, but you’ll have to change account names each month. Simply go to the 360’s dashboard and “sign up” (by signing out of your account) and register a new name. When you fill out all the information (make sure the zip code and the city are correct, but you can use any city/zip combo like Beverly Hills, California, 90210 works) and finally get to the payment options, select Silver membership. It’ll ask you if you’re sure, so just hit yes that you’re sure, but then it will say you qualify for a free 1-month trial immediately. Just take the 1-month trial and play as you please. When your month runs up, you can just make a new silver account and get another free 1-month trial again. I regularly have guests over to play, so instead of making guest[1] and such and only getting to do social matches, we can make a bunch of free 1-month trials and everyone gets to play ranked then if they want. Good times! edit — I have been informed that there are only three 1-month trials of Xbox Live Gold (you can have as many Silvers as you please AFAIK) per x360. Still not bad!
As in just sign up for a new account? I prosumed you would need a voucher code sort of thing?
Nope, you don't need a voucher, you according to that quote ^^^ each xbox 360 has 3 free gold trials, give it a go, it might work :)
EDIT: if it doesn't work, i think i have a couple at home, i'll have a look for you! :)
Unfortunatly no free trials left with this xbox. Would appreciate it if people could send me any free codes they have. 24-24 or a month would be great. Will see how much I use it and then buy it for 12 months. Thanks in advance
