Xbox live wireless
10 Jun 2006
Wigan
I just got the official wireless adaptor for me 360 and when i try to connect to my network it finds it fine and asks for the wep key but once all that is done and i go to the xbox live test it says
Wireless adapter : USB wireless
Wireless network : not connected
but now if i go to find networks again it says my network is connected, but it still fails the tests,
I have tried google but had no luck :( anyone here had similar problems?
Thanks
Switch off encryption for your wireless network and try then.
If it works, you are entering the wrong key on the 360.
Check your wireless router to see if it's assigning the 360 an IP address by DHCP.
If it's not, make sure you are connecting to the correct wireless network, and try positioning the two closer together to rule out signal trouble.
They are both in the same room, the signal is perfect, i am not blocking the mac at all but on the dhcp screen it doesnt even assign my 360 an IP,
I have tried everything i can think of, if i plug in the ethernet cable it connnects instantly :(
