Xbox Media Center quick question
24 Sep 2005
Middlesbrough
Just setup my Xbox to access the PCs files.
Question is, will the Xbox remember the files and not have to re-add them each time I open up the Media Center?
I have an awful lot of files :(
For media center on the Xbox, you have to make sure you have 32bit decoders installed on the PC that will play the types of files you want to run on the 360.
I'd definitetly recommend TVersity over Media Centre. I tried to get Media Centre to do everything I wanted and it was a right pain in the backside.
TVersity is so simple and can stream anything you like :)
Installed TVersity at home remotely and it looks a little complicated to get my custom drives into the system.
Will have a play when I get home :)
Or not.
Add item - E:\ (Submit)
Scanning drive ;)
