Hi, first time on forums.
I bought a second hand Xbox One almost three years ago but very quickly developed issues with it within 2-3 weeks. At first everything seemed to be working fine then sporadically it would not read discs and the problem got worse until it wouldn't read any discs at all and on top of that with a disc inserted it would not eject, as if it didn't even recognise a disc was even inserted. The only way to eject was to hold in or repeatedly press the eject button whilst rebooting. I've been using it only for digital downloads running off the hard drive.
The other issue which is really weird and didn't crop up till I got a USB controller and external hard drive (as I didn't have any USB peripherals attached to start with), is that the machine will not boot with any USB attachments at all, it will hang on a green screen forever. To boot the Xbox I have to remove all and any USB attachments, let it boot up then attach the external hard drive and any USB controllers. There are no issues with the USB devices themselves, they work perfectly, but with anything attached on any USB port seems to interrupt the bootup. Once booted, there are no hangs or crashes whilst using a USB device.
I don't mind so much that discs can't be read, games have to be installed to HDD anyway but it is a pain with the Boot issue having to disconnect and reconnect peripherals on each startup or reboot especially during updates. I've resorted to having no external hard drive attached at all and using it on my PS4 which is now my main gaming console.
When starting up I have put my ear close to the internal hard drive (not actually opened up the console) to listen to it on boot. I can hear it spin up then when it gets to a certain point it stops spinning whilst a USB is attached, with no attachments the hard drive continues on and completes the boot. I've tried as an experiment to boot with different attachments on different ports then remove them at the point where it hangs but once it has hung it will not continue and can only power off.
Has anyone else had this issue or heard of it? I have looked through numerous forums and searches on google but nothing like this comes up at all. Any ideas what the problem is and if it can be fixed?
