xbox original fan replacement
13 Jan 2006
Wigan
anyone replaced the rear fan on an original xbox?
using it with xbmc atm and decided its time to put in a quieter fan, anyone who has done this can you say how difficult it was to do and reccomend a quiet fan that shifts enough air.
thx.
not very hard IMO. I put a quiet 80mm fan in there. I had to chop away some of the plastic and metal casing. It was a while ago now and I don't have it any more but it didn't take too long and made LOADS of difference. I think I ran it off a 5V supply.
xbox-scene will probably have a tutorial
