XBOX +PC
6 Jan 2004
wishing i was somewhere e
Hi can anyone tell me if it is possible to connect my xbox360 and pc to the same monitor and if i can what do i need ? :)
You can do it, what you need to do depends on your monitor. If you have more than one input it might be as simple as a cable, otherwise you need a converter which is more expensive.
If your monitor has DVI+VGA, get the Xbox360 VGA cable and use DVI for your PC, most recent (last few years) PCs have DVI sockets on the graphics cards :)
Is it possible to get an 24" HD screen? Sorry for stealing your thread a little calamity :p
720p = 1280x720, 1080i/p = 1920x1080.
Most 24" screens (in fact all that I know of) are 1920x1200 so yes, you can.
