Xbox problem.
13 Dec 2006
Hey guys,
Got a weird problem with my Xbox... It's was all working fine and I unplugged it all to move it and since it's been moved its not working right. When you turn it on the green light on it lights up and the controller powers up but it doesn't assign a player number to the cotrolller or display one on the console and it is not displaying a picture. I have tried changing between hdmi and component but it doesn't make a difference the console is a slim by the way :)
Controller problem, I've had before, I sorted it by taking the battery pack of for ten minutes then re-pairing it with the xbox. The no picture problem I can't help with though.
Not sure but one thing i'll add anyway, when I turn on my xbox slim, it doesn't 'start up' untill I switch the TV on (HDMI) and it can display so it could be a problem with not being able to display so just does not much at all. IE if I switch my xbox on then 5 minutes later switch my TV on, the first screen with the swirl shows up, then the dashboard and controller assignment.
It's not anything to do with the signal afaik as I tried that and I did it with both sources. I shall quest on and see what's afoot but it's annoying me as I have both forza and BF3 to play :-(
Also is there anyway given its state to transfer data from one slim to another as my forza save is on it and I've put done decent time in to it so would rather not start again :-(
