Xbox 'resets' when I change input
Caporegime
21 Oct 2002
Here
Copied from my post on the Pioneer 5090 thread on AV forums:
Heres one I havent seen mentioned before. I have a 5090, there is no Amp involved as my HDDVD player and BD player are plugged into the AMP via HDMI. The amp only processes the optical sound from the Xbox and Virgin box
When I am playing on my Xbox (Direct to Input 4) via HDMI and want to flick to TV, (Direct to Input 1) again via HDMI from the V+box, the Xbox resets.
Its goes into some standby mode even if I am in a game, then when i go back to Input 4 the Xbox restarts.
It does exactly the same when I turn the TV off.
Is there anyway of stopping this? I want to turn the TV but leave the Xbox running the background sometimes (like I think I can with other TVs)
Cheers
Simon
Can anyone shred some light?
Cheers
This is annoying now for when I wanna leave it downloading and watch TV.
My Samsung upstairs in my room doesnt
My mate had this - swapped machine and the new xbox doesnt do it.
The 360 has a very odd way of dealing with hdmi and pioneer are famous for being awful with hdmi issues so it may be a combo of both.
My panny is fine for switching inputs with 360 but if i turn the 360 on and im not on the right input the 360 just pauses the bootup and only continues when you go to the right input - infact thats via my amp and thats yamaha !
they dont handle hdmi brilliantly, my falcon resets if i switch inputs on my amp. it also has to be switched on after the amp otherwise it'll only give me two channel stereo.
