Xbox Sky Go Problem
30 May 2003
UK
Hi,
Accidently entered "Party" mode where you get a reducded screen size and your avatar sitting in some room and now I can't seem to get out of it. I can go to fullscreen but when hitting the B button to go back it just takes me back to the room rather to the menu like it used to.
Anyone know how to quit out of "Party" mode permanently?
Thanks,
Neil
There's almost certainly a proper way, but just delete the app and re-downloading should sort it quickly too?
Did you delete everything from the storage section in the dashboard, including the Sky Data file?
Seems weird it would go straight back into party mode if so?
press the guide and leave the party you are in
Yup this'll do it. As you're in a party (probably by your self, or watching with friends) it adds you to this random room.
Leave the party and you should be alright :)
