Xbox style controller for ps4
2 Jul 2008
Near London
Hi all
I have just picked up a PS4 Pro but struggling with the controllers, I prefer the stick layout on the Xbox controllers. Can anyone recommend an Xbox style controller for the PS4?
I had one of the Razer Raiju Tournament controllers for about 6 months. Absolutely awesome bit of kit with the best buttons I've ever experienced on a controller. The stick drift was horrific though so ended up sending it back. Seems like a fairly common issue in most aftermarket controllers.
Thanks for posting. I was only looking to spend around £50. Guess I will just make do with the current controller.
The Nacon Asymmetric and Revolution pads are worth a look, I found the Asymmetric to be a solid piece of kit personally. Hold in mind one or two features are missing compared to the official controller such as not having motion controls, I'd definitely read up on it before buying.
There's the Hori Onyx which has a similar layout, but I'm not sure I'd bother taking a chance as I've seen a lot of negative reviews on it.
Outside of that you might be able to find a no-brand Chinese equivalent of the above for less money, but they'd be a bit of a gamble.
