So I turned my Xbox on today for the first time in at least 2 months. I was greeted with my usual Profile Sign-in, and then informed that there was an Xbox Update, and that if I didn't proceed with the update, I would not be allowed to sign in to XBL. So I hit Update, and the download bar shows the progress.
However, once the update reaches the end of the bar, it goes back to the start and then an error message comes up saying that the Update was unable to be completed, and that I had to check my connection settings from the network menu. Now when I go to Network Connections, I run the Xbox Live Test and everything goes fine, until it reaches the Xbox Live test, then the pop-up menu comes across again asking my to update. Everytime I try to update, the download appears to go fine, but then I get the error at the end.
Anyone experienced this before? Ive already stated this before, but im using the Wireless Adapter for my xbox, but running the connection test everything is fine. Its just the Xbox Live test that fails. Its got nothing to do with my membership/subscription, as it doesn't run out until October afaik, but even if that was the issue, I should still be able to sign into my Silver Subscription, but nope, I can't sign into Xbox Live at all.
Any help ASAP would be s00per d00per.
Thanks guys.
Thanks guys.
