xbox water cooling with pc
20 Oct 2009
Does anyone know what blocks i can use for the cpu and gpu in the xbox?
I am after running my xbox water cooled along with the pc, they will share the cooling system, as i will only be either using one or the other at anyone 1 time, i have a massive radiator with a 12 inch fan for 2hen it gets really hot from an old dehumidifier which should be enough to cool both down even on full wack. Also thinking of runing 2 colours and seperate the gpu's from the cpu's. Im doing it more to look good as 2 seperate systems would probably be more practical.
anyway would there be any problems that i havnt thought about with what im doing?
And any input?
Seems quite a lot of work for not much return really, especially whith the next gen just round the corner.
my 360 is annoyingly noisy pretty much all the time. but going to the expense of watercooling it seems abit of a waste of time as its never overheated and cant be overclocked etc unless noise is an issue ofc
noise is an issue, and its going in a tight spot along with the pc and been told if the vents are blocked then it will overheat, im not gonna worry about the new one for a while besides i can always water cool that after.
What it is is my room is very small, just enough room for a bed and ive built in a cuboard on 1 side of a chimney breast, the other side is where my tiny tiny desk goes, i cant even get 2 x 19" monitors side by side so gonna go for 2 x 24's above each ot and the pc has sat in the way of the cuboard along other, with hifi and stereo with wires everywhere.
There is a gap in the chimney brest about 100mm where the pc etc are gonna be wall mounted, along with xbox, tv, wifi, nas box, cable box, virgin box, amplifier, blu ray, along with all the bloody wires plugs transformers network leads etc. theres no real ventilation so managed to force an old aircon rad into the old fire place with a fan which will hopefully vent heat upwards and out the chimney, ive drilled 2 holes for the pipes to run the watercooling and get rid of every fan i can.
so you can see my dilema hopefully, and hopefully it wont all blow up in my face :p
Thanks for any help
