Just got around to instaling my xbox pad again and found the receivers led was not powering on. Then found its not being noticed by pc.
A bit of google magic later I found it was most likely one of the fuses that had blown.
Found a fix, but it involves bypassing said fuse with a bit of solder.
Warrenty is long gone so my options are,
Buy a new reciver, £14 after a quick look.
Or fix with the solder, i would need to get soldering equiptment etc plus zero experience.
Advice chaps?
Advice chaps?
