That wouldn't be the case, I think MS have said they'll not consider it, or wont do it for a while anyway.Nikumba said:The 360 will not have a built in HD-DVD drive since the HD-DVD drive cant read the data of a normal DVD quick enough from what i remeber
Kimbie
What are you talking about? Adding a HD-DVD drive wouldn't add any more heat at all I wouldn't have thought, it's just a different type of laser that'll read the disc, and it spins slower too I believe.steveo said:the hd inside the 360 is a bad idea they already struggle with heat and adding a hd would really push it over the edge imho and the only way they could combat it would be to stick more fans in which would increase noise![]()
DaveyD said:What are you talking about? Adding a HD-DVD drive wouldn't add any more heat at all I wouldn't have thought, it's just a different type of laser that'll read the disc, and it spins slower too I believe.
