Xbox360 3D Mark 06 Score
10 Nov 2006
Lincolnshire
Before I start this is not a "PC is better than xbox360" or vice versa thread, if it turns into one some-one please close it down as theres been plently in the past. I was simply wondering if it was possible... what score would the 360 pull on a bench test like 3D Mark 06.
Any ideas?
Any ideas?
Is it not based on a 7800GTX graphics more or less, probably about 5000.
Just because its a bigger number?
When a 256mb R600 comes out, with 10mb of whatever memory it is, running on a 3.2 ghz system with 512 of ram? I think
Then itll be roughly the same specs, obviously the 360 is optimised, so its not like for like, probably be a bit more on a 360, but at least it would give you an idea of what sort of spec gaming pc you would need!
3D01 is more CPU dependant. Also there are no triple core PC processors out there.
